After performing all the above suggestions, recheck. Write results down to keep track of what you have done. Be methodical.
Points gap - Adjust, clean points, check points for alignment. .020 - .022
Timing - Timing pin, points just open with spark advance lever fully up retarded
Rotor- when the Dist. cap clips are removed , does the cap spring up slightly?
Old Style Plates - Remove upper Plate, inspect pig tail, original plates or wireless plates?
Check if Sheathed cable going into distributor is screwed in too far - Can short out cable internal inside Dist.
With points closed, ignition on, use dowel or something plastic to open close points - Nice blue spark on opening. If bright blue flash and can hear a snapping sound from the spark, probable bad condenser.
When cranking motor with ignition on - Does ammeter wiggle - indicates primary side of ignition is most likely OK. Do not leave ignition on points close for more than a minute or 2, coil can heat up.
Coil - with terminal leads and coil/dist. wire off off, ignition off - On 6V system use a multimeter on Ohms, measure across the screw terminals - 1.5 ohms. Measure each terminal individually to the center coil high tension lead terminal/socket - 10K -15K ohms
Remove one spark plug lead at the spark plug. Place the lead about 1/4" from the spark plug terminal. With ignition on, crank motor, should see a nice blue spark. If weak blue or yellow, possible bad connection or coil.
Remove a spark plug, with lead on lead ground plug to a clean head bolt - ignition on crank motor - nice blue spark.
As stated previously a bad timing gear - not sure how to check for that without taking the cover off - perhaps others can help.
If pouring gas directly into carb - after a no start, pull plug - should be wet from gas or smell like gas. Inspect plug - clean and gap
