I Need an Oil Pan Drain Plug Gasket
leo
So I dug through my collection of odd's and end's and found this. It's 15/16 outer diameter, 7/8 inner diameter and 1/16 wide. Am I in luck?
Looks good to me. Does it fit the drain plug?
Thought I heard that a spark plug washer would work as well?
Jeff
We found the copper one to leak, even after filing flat the pan mating surface. Used the fibre type with no leak so far and not overtightening the bolt. Perhaps a little Perm 2 as Bill suggests would help.
The A vendors sell them either alone or in the kits. They are a hard usually gray or black composition material, not cork. see post 9.
