54HotRod
I pulled the 1984 351W out of my 54 Customline last week and now I"m contemplating if I should just clean the grease off the engine and slap her back in or do a rebuild. When it comes to a rebuild, I don't know my a** from a hole in the ground. Pretty much I will be learning as I go just as I have with everything else on this car.
So the part I need advice about is what parts do I need for a rebuild. I don't want to make the engine a super power rocket that goes mach jesus. I have a car that is a custom, so if anything I just want my engine to be reliable and have a nice low rumble almost like a flathead. Currently I do still have points and I would like to change that out. Also the coil is a bit old and I would like to be upgrade that as well.
Last year I purchased an Edlebrock Endurashine Dual Quad performer series intake manifold and carburetor set up, but I was told by a friend that it would cause the engine to become sluggish if I put it on before changing the cam. I really like the look of the equipment and I'd like to have it on the engine. I'm looking for advice of what parts will keep the engine at a normal sound but not cause the engine to become sluggish. Obviously I don't want to spend and arm and a leg but I also understand that some things are just expensive. Also, how long should it take for a shop to clean and inspect the block or whatever they do to make sure its not jacked up?
Thanks for taking the time to read this and hopefully for advice too.
