I know it's warmer here today but Jeez...
Mart
While we all welcome a bit of warmer weather after a cold spell, watch out for condensation. In an unheated garage all the big heavy items will attract water. Check out what I found today.
https://youtu.be/qyZ4wn2XP94
505788
Re: I know it's warmer here today but Jeez..
One of the first things I learned when I moved into my new shop was that a dehumidifier is an essential piece of shop equipment.
Also keep the doors shut as much as possible.
And when you build a new one, make sure that the floor has a vapor barrier.
Humidity, sinkholes, and hurricanes, Oh My!
I'll take the earthquakes, sunamis, and wildfires of the Left Coast, thank you.
Oh oh, yeah, we've got that "P" stuff going on, but at least it doesn't make our socks moldy overnight.
The P word that comes to mind here is what our Seattle news meteorologists call the 'Pineapple Express'. A band of warm MOIST air that shows up in the fall and winter at times. That's when all the iron in my shop gets wet even though the roof doesn't leak. I still haven't figured out what the SF area gets that starts with a P. Phog?
Wood stove, nice and dry in here, and 80 degrees while its about zero outside. Nice and cozy
yeah Mart, I feel for you...my shed is like that in the winter; I've gotta keep plenty of oil on all the machine bedways etc, lift the hood [bonnet] on the 35, the engine is just dripping. damn annoying ain't it?
The “P” stuff… questions coming in even by PM! You guys only have to think of what we can’t post on the Barn for a clue to what’s happening on the Left Coast.
Typical Jolly Ole England I suppose. Big Inch Flatty looks good in any weather, but sorry about the "quick rust" bores though. I think "cheers" isn't appropriate here. God bless Ya Mart!
I agree with Tubman, I learned early on that my shop needed a dehumidifier. Best money I've spent in a while. Keeps things nice and dry. And it actually makes it more comfortable for me while in the shop.
I keep the heat on in the garage and keep doors shut most times spring and fall. To cool for humidifier. Have some big ceiling fans in pole building running and cringe at the thought of having to open the doors when it's hot and humid out. 4+ F right now. Our humidity is solid for a couple of months now.
“Our humidity is solid for a couple of months now.” ya, ours too!....I got a dehumidifier in one building and I hate opening my shop and barn till the cement slabs their on warm up in the spring. I run fans with my tool box open till it dries up.......Mark
10 below zero, and still 80 and dry in the shop with the wood stove. I know, I am being a jerk here, many don't have the option like i do. BUT... I will say, David was correct in the post above, vapor barrier is important. Too late now for most folks, but if building a new shop put heavy plastic under the concrete floor. Makes a huge difference. Another thing I did for my harsh northern climate is put 2" high density foam down 4' around the slab to keep the frost from getting to the concrete. That way, the floor is always at earth temperature, generally about 54-56 degrees, so at that temp an insulated building will never freeze inside even with no heat at any temp. My old shop was like Marts, tools rust INSIDE the tool box, no need to leave them out in the driveway to rust. The dehumidifier certainly is a help for that, I had one that I modified to drain out thru the wall so no need to empty the container. I do not know how much energy they consume, but not bad I would guess. I also run a small window AC unit occasionally in the humid days in summer. I only run it a short while, mainly to dry the air. It will never bring the temp down much, but the dry air is a great improvement you notice the second you go outside. I run the AC so little that I see no difference in the electric bill, but the shop is a much more pleasant place to hang out, which is what I do pretty much all day...everyday !
We are supposed to have lows at zero to minus 3 here in Southern Illinois, Friday through the weekend. Wind chill is predicted to be 20-30 below. I have a heated shop but it's going to be hard to get motivated to get out there with the wind chill factor. This is unusual for where I live. Stay warm.
