The car has some kind of crazy Bendix unit on it and I want to swap it with a duel bowl master power set up. I am staying with the 4 wheel drum. Can anyone tell me what would fit?
Go on Ebay and get one from Irish Dave. Tell him it's for stock drum/drums. Put that setup on a '56 Vicky in the past. I'll see if I can get you some more info.
You can deal Direct with Dave without ebay,phone is (575) 544-4729 cell is (575)494-5119 make sure you get the kit with the dual diaphragm booster the single diaphragm units totally suck.Dave uses a Corvette master which requires a residual valve,the Mustang unit I posted below(post#4) does not and you will be 100% FORD.This also works and is dirt cheap: http://www.fordfalcon2000.com/restoration/powerbrakes.htm
