HydroVAC units were the earliest Power Brake units and were used on many vehicles, both domestic & foreign.
I installed one on my 1956 Ford Fairlane (car is not on the road yet).
If you have a dual Master cylinder on your car you will need two of them.
I am using an original new single Master on my car.
The hookup is pretty straight forward: Mount the device, run a vacuum line (3/8" diameter) directly from the intake manifold to the unit.
The brake line from the original master cylinder is routed to the Hydrovac unit.
The line to the brakes is then. adapted to the output from the Hydrovac to the brakes, as original.
Brake bleeding is first done by bleeding Master to Hydrovac, then regular bleeding to the rest of the system.
Here's where I got mine from a Company in Australia. The total price (delivered) was approx $ 150.00 (exchange rate considered). It arrived in 3 weeks.
You will be pleasantly surprised at the quality & completeness of the unit.
I'm told that it merely doubles the output line pressure to make braking easier.
I didn't want to clutter up the engine compartment in my car with the big diaphram
type used in newer cars, and like the option of the remote mounting.
If I had enough vacuum in my 32 Ford Flathead, I'd add one there too.
Here's the info:
http://www.ebay.com.au/itm/VH44J-26...ds-FITTING-KIT-BB-061-BXBOOSTER-/321837676809
Happy New Year
Jim
