hydraulic fluid
Rich Overton
In the '46-'48 Service Manual, Ford specifies M-3833 hydraulic brake fluid for the master cylinder and M-4633-B for the shocks. Are these still available or can other product be used? ie; I have DOT-3 brake fluid on hand will I be OK using this for the master cylinder. What can I use in the shocks?
Thanks very much barners for all the wonderful advise and information gathered here. You are all great! :)
Rich O.
If the shocks are new ask the manufacturer. If the shocks are rebuilt ask the rebuilder. You should know what type of seals were used on the shocks.
Charlie Stephens
I did some testing of clutch slave cylinders a long time ago and we found that Dot 4 fluid was far better than Dot 3. Other than a brief excursion into silicone fluid 25 years ago I've used Dot 4 in everything I have had since.
Mart.
Thanks Vic, Charlie & Mart.
I am quite sure that the brake cylinders are original as well as the shocks. Is Bill Wzorek on this site or do you know if he has a web site?
Thanks very much again !!
Rich
Bill is on the FordBarn and he just started the community group "Frends of the Old Barn", you can email or send him a PM.
do not put brake fluid in the shocks. it will cause them to leak. that was a proulbem years ago when these cars were every day cars. i don,t know about dot 5 it was not around then.
