Anthony...Let's back-up and regroup. I believe you have a flathead, correct? Is it true that you are also still running the '35 transmission? Are you in fact still set-up actuating the STOCK '35 clutch ARM that moves the throwout fork? If so, allow me to guess that your current necessity to utilize a hydraulic clutch comes as a result of utilizing Richard's hydraulic brake mod, which probably does away with part of the stock clutch operating mechanism.
We really need a few more definitive facts about what you have. Because of pedal ratios and clutch arm and linkage dimensions, you can't just pull the answers out of thin air. Otherwise, you'll end up with a clutch that won't fully release, or a clutch pedal that is far too hard to easily push with normal force. DD
