hydraulic clutch
fordmanbob
New member
i'm trying to put a hydraulic master cylinder and slave cylinder with a 39 gearbox,behind a 239 flathead. The clutch and disc was bought at swap meet with aluminum fly wheel. Will this work with a steel flywheel?
You are on the wrong forum. This is a question for the H.A.M.B. not Fordbarn.:mad:
:rolleyes: But Mike, ...it is in a Model A so let's all discuss it!!
I'm using a 10" clutch pressure plate and disc that I used with a steel faced aluminum fly wheel on a "stock" early flathead flywheel. Bolted right up if that is your question. Let me qualify this, I 'm putting it on a model "B" engine in my 29 RPU, Don't want anyone getting their underwear twisted
