Darn Pete, if you didnt live so far away i could lend you mine, but its the 3 legged type and its heavy, im in calif and the shipping back and forth would be out of site, maybe some one else on here has one you can borrow. any one?
Pete check and see if you got drums with the groove around the hub or the shoulder. I bit the bullet and bought the K R Wilson puller for 150.00 not giving a thought that the other drum on the other side was different (it had a shoulder) and the K R wIlson wouldn't work. I bought the cheapie from Snyders that works on the shoulder hub. Now, I got one of each. Live and learn I guess. I'd lend it to ya, but I'm in Pennsylvania
I have this type puller ( great for old MoPars and Nashes ), but I've been reluctant to use it on the A; I'm concerned about possibly distorting the lug-flange of the drum...
Is this a valid concern, or am I being too cautious ?
I use a 6" Snap=On two arm puller. I have used this puller many times on the rear hubs and it works fine with the assistance of an impact gun. It can also be used for many other things as well. It is very high quality and very adjustable for length and width of application. It will work with either type of rear hub.
The KR Wilson rear hub puller can give you headaches at times, so I made some adjustments to it. I now have an "enhanced" version of the KRW that I manufacture. Check it out here: http://vintageprecision.com/products/hub_pullers/index.html
