Hub puller (again)
pdora
Yesterday I started a thread asking about rear-wheel hub pullers.
I forgot to state that my 1930 Tudor brakes were converted to hydraulic by an unknown previous owner. The hub and drum appear to be 1946-1948.
What kind of hub puller do I need?
Thanks
Same, no difference between Model A pullers and later V8 pullers. Just get on that pulls on the hub ring and not the wheel studs. If you get one that pulls on studs, you risk, breaking studs, warping the hub/drum, or breaking the hub/drum.
Ebay HUB Puller
Also avoid the knocker type. This type threads on the axle, then hit with hammer. This type you risk damaging axle threads.
