daveymc29
Here's what I hear, it sounds like my hub cap are loose and send a hollow tinnie sound out when I hit bumps. These are repo later Ford caps for the 1935 Ford wire wheels on my 29 roadster. I just had new tires mounted and know the hub caps are tight as are the lug nuts and no loose parts in behind the hub cap. The noise was there before the new tires and nothing has changed. So, how do I combat this? Not going back to the 21 inch, dents and unbalanced wheels I lived with for years. I wonder if others have had similar problems and what they did to cure them? I thinking of some caulking with the caulking gun and then clean the wheel and rebalance?
