Topher5150
I have a 351W sitting in a chassis with no wiring harness, but I just want to try to fire it up and get it running for a few seconds. I found a duraspark II (blue) box and some wiring. Using the attached diagram
-I have a little starter button from ign. sw. red wire from the battery to the first small post, then from the first small post to the duraspark.
-then from the second small post to the coil +
-then from the coil - to the duraspark
This is only to fire up the engine I know there's a lot more that needs to be done to it. I just want to see if the engine starts
