Simple Alternator Test:
1) Start Car and run at a normal idle.
2) Connect a Voltmeter Directly Across the battery Terminals.
3) Turn on Headlights to High Beam.
4) check the battery Voltage.
*** The Battery voltage Should read between about 13.8 to 14.2 volts. (Possibly up to 14.5 Volts.)
5) Increase motor speed to about 1500 RPM. The Alternator should now produce a battery voltage between 14.2 and 14.6 Volts.
*** If it is Lower than 14.2 volts, the Alternator probably has one or more Bad Diodes.
6) Now, Maintain the 1500 RPM and Turn off the Headlights. Run this test for One Full Minute.
"The Battery Voltage should NEVER Exceed about 14.8 Volts".
***If it Does, the Alternators Voltage Regulator is probably Faulty, OVER CHARGING the Battery.
