How to rig temp fuel delivery
alexiskai
I'm helping someone sell a Tudor that's been in storage for a few years. I want to show in the listing that the car will run. But I'm pretty sure the carb is gummed up, and there may be rust in the tank. I want to rig a temp fuel system just to confirm that it will run once the carb is fixed.
I have a working carb I can attach temporarily. I want to use a simple gravity-feed system with a jug and a flexible hose to feed the carb. The problem: I've never done this and I don't know how.
Can someone explain to me how this is done? Like, what kind of connectors do I need? What kind of hose do I need? What kind of container do I need? The whole thing is a mystery.
I had to do a similar rig not to long ago. Rigged up a plastic gas mower fuel tank and ran a rubber hose with hose clamps onto the gas line to the carb, worked fine
OK, so you take the fuel line off the firewall-mounted filter and then you clamp the flexible hose to that on one end. Then you use a small tank or even a gas can on the other end. Seems reasonable. Thank you.
Before you do that, try to clean out the line from the tank and see if it will flow. You can dump about a gallon of gasoline with some tank cleaner in the tank, then shake the car to help clean it out. Toluene is a good cleaner.
Also I've found that in my experience that Model A's don't like it when a fuel line has a dip in it making the fuel run uphill to the carburetor. When hooking up a temporary tank I make sure the fuel line runs down hill all the way to the carburetor.
I have a steel fuel line that I cut off about four inches from the carburetor that I use to attach a flexible hose to and run that to my temporary tank.
