36tudordeluxe
Without getting a rear axle bearing puller & slide hammer as this is a one time only operation; does anyone have a method of removing the axle bearings from a Ford 8" axle housing?
Any 8 inch I've ever seen had the bearing on the axle and a seal in the housing.
A slide tool is the best way to remove the seal.
Once the axle is out, a press is needed to remove the bearing off the axle. Local auto parts store may have the press to do the axle.
To remove the axle, undo the four bolts holding the cover plate and pull
Back in the 60s we would cut the ring and bearing off with a torch, and the install the new one by putting the stud end of the shaft on a short chunk of railway steel we had. We had a 3' length of heavy wall pipe that would fit over the larger diameter of the shaft. We then would put the bearing and ring back on the shaft, put the pipe on the shaft and commence to hit it with a BFH until it was seated properly. I still use the same method, and it still works.![]()
