nomadpsd
This is a video on how to remove ethanol from your gasoline. Very simple process.
https://www.youtube.com/watch?v=b9mLbuUSt-0
That's a very simple solution to removing the ethanol. Non-ethanol gas is nearly a dollar a gallon more expensive. That's about $10 a tank on a model A
If you remove the ethanol from 87 octane pump gas you wind up with 76-78 octane.Not important in a Model A though,67 octane was good gas in the A days.Ethanol is not added to regular gas,it is added to gas refined to a lower octane.I've hauled some gas,I found that out at the tank farm years ago.
Keep in mind, in some locations ethanol is a hazardous chemical and needs to be disposed of property. Even in a diluted state.
I’d rather pay the extra $1 per gallon to directly fill my car. I don’t want to haul the gas cans to be filled, and then try to remove the ethanol from 10 gallons, I’d need more containers to transfer the fuel into, add water, drain the water mix, and then put the gas back into the gas can. Way too much hassle to save $10!
