Once you've revolved it into the open position [ie where it's ready to receive ash], simply pull the ash recepticle towards yourself. It simply pulls off. [this is so one can empty it] Then you can rotate the cover back 90 odd degrees to access the screw that holds it in. undo the screw, and the rest comes out, leaving the bracket still attached in the dash, that unclips; one side then the other.
