Or you can go here and save $
https://www.ebay.com/itm/Glyptal-Br...736303?hash=item4214bc73ef:g:MR8AAOSwLfNebhRv
Brushed on, it also works like a charm on '32 aluminum oil pans which are porous enough to actually sweat oil. As noted, however, absolutely clean surfaces are a must.
That sounds do able and a lot less equipment to deal with. Thanks for the tip.I use a heat lamp to help "bake" the parts as they dry. I move it around during the process. You'd be surprised how hot they get parts
Hi; Just note. while available for electric motor rebuilding and insulating, the SPRAY can versions work also, BUT use Good respirators, not just masks. It can coat your lungs also. Newc
I already have it so I may as well use it or toss it out in the disposal site. true Probably not needed but it may help keep the sludge from sticking.It has been used for years in high performance engines to increase the flow of oil over surfaces back to the oil pan. Is it needed in a mild built flathead, probably not, but that applies to a lot of things! I use it.
