Randy
My oil pan gasket set did not come with the rear pan seal. I was looking at an old one and it appears to be about 1/4" thick cork. If I can find some 1/4" cork, can I just cut one out of that or is a better way?
Also, is there any kind of seal around the oil pump body where it goes up in the block? Something crumbled out of this one when I removed it and I can't tell if it used to be some kind of material or if it was just sludge.
Thanks.
Thanks.
