How to install running board stainless trim
mot ecnal
I have my new rubber running board covers installed, but can't get the stainless trim to clip over the rubber covers. Anybody have a solution? Thanks
While you did not mention the year of your running boards, the original attachment of the stainless trim to the boards was spring clips through the rubber and holes in the underlying steel except at both ends where the clips had threaded studs secured with nuts and lock washers. The required holes in your boards are normally there whether the car originally came with the stainless trim or not.
If you are taking about 42-48's, you will have fun.
I slipped the bottom on and then using a 1" piece of wood and C clamps to force them on over the top. It took many trys, but finally got them on. They were orginal trim parts but the rubber might be thicker. I would like to hear other ideas.
I did forget to list the year of my car, it's a 1947 coupe. Thanks for the advise on how you did yours. Anybody have a better solution? Thanks
When I did my '46 I had NOS running boards and trim. The trim was snug but a firm slap with my hand popped them on. I suspect the new rubber is a little thick on the edge so you may have to resort to wood and clamps.
No one makes the hardware to attach the running board moulding on a 35-36 that I know of.I used fender washers and tig welded a stud on the washer.First trim the washer so it slides in the slot easily.
I'm new to your forum and will be asking a lot of questions. To start, I'm installing the running board trim on a 1930 Standard coupe that I'm restoring. I purchased the SS trim from Mac's. Does anyone have any photos of the corner detail or can you describe how to finish the corners. Any tricks would be appreciated.
On the 35-36 trim you can get universal "trim to fit" clips with studs already mounted in them. Some V-8 parts suppliers and I think LeBaron-Bonney carry them.
