ford28roadster
in an effort to cure my wheel shimmy on a 28 roadster heres what ive done so far. removed the steering shaft sector the 2 bushings and the pitman arm. what I found was pitman arm ball not very round and sector shaft worn . the teeth are worn in the center. the new bushings fit snug on the new sector shaft but slack on the old and the old bushings fit snug on the new sector shaft but slack on the old one. to remove the old bushings I used a socket . question how s the best way to install these bushings ? is there a certain tool of a certain size ? thanks im a novice at this but so far so good john
