When I started a friend's engine for the first time, He didn't have anything to screw into the distributor, so I used a cork and nail. Connect the wire from the distributor to one side of the coil primary terminal and connect the negative from the 6 volt battery to the other coil primary terminal, just as IrishHills shows in the diagram above.
