rotorwrench
I wouldn't cut them out unless they was no other way to repair them. I'd first try to make a tool to buck the back side so it can be smoother out in place. Cutting is a last resort. Those 1937 grills are pretty delicate. If you remove one, you will need equipment and skill to weld thin small parts without melting the stuff. If there is plating on it, it will have to be completely removed. If it is stainless, you will need to fabricate tooling to deal with each problem that is different such as dent or twist. If you fabricate a tools with the proper width, radius, & curvature to fit in the backside of the bars, you can work them but you will have to gentle on those small grill bars. If the bars are spot welded in place then they can be removed and spot welded back but it takes experience with welding stainless or what ever material it is. Resistance welding equipment isn't cheap.
