38 Conv
Got a frame mount power booster brake set-up on a 1955 Ford F-100 best way to adjust rod from booster to pedal not to keep pressure on MC----- front pistons do not return all the way back in after brake pedal is released, proper return spring installed on pedal -- pistons will return if you insert screw driver thru hole to make them release then rotors spin free the correct way they should----only 200 miles on conversion--- Thanks
