I screw the big screw in until i can put a cotter pin in. If, as you say, all parts are good, that should work.
Ok guys, let's please stick to the original question to keep it simple! When I move the wheel when jacked up side to side, there is a small amount of play in the tie rod end and tie rod. How tight does this need to be? Thank you.
Paul Shinn video on You Tube, Model A Ford drag links. 10 minute video. Will answer your questions.
Go to You Tube model a ford drag link.
Enjoy.
