How much grease in the clamshell?
Ring type universal. Used on most pre-1930 Model A. No seals. Designed to be used inside the "clamshells" (actually a semi-spherical joint which joins the back of the transmission to the axle.)
The "modern" Dana-Spicer type yoke & cross universal. As used in 1930ish and beyond Fords.
Here is an image of the Dana-Spicer unit showing the later universal "broke down" into non-yoke parts. Each of the prongs of the cross is covered by a sealed one-sided needle bearing. The unit is assembled to the yokes by use of the "snaprings" in the bag.
If you were to buy a replacement Model A Universal today - this is what you would get. Lubricated for the life of the universal and sealed against the entrance of contamination.
Some D-S production may include a zerk to grease the needle bearings. The zerk would be inaccessible in the clamshells.
Joe K
Without disassembly of the clamshell halves and a bit of a "pull-back" to the rear axle - probably not.
The inner "half sphere" (mounts to the rear bearing retainer of the transmission and is normally covered by the half-shells) has a couple of holes which I surmise one might be able to use a strong flashlight and look into to see the universal - but I think the matching half sphere of the torque tube covers the holes.
A required "pull back" of the axle should be just enough to pull the two mating half spheres to the rear and see the universal within. With the brake rods dis-attached, this might be possible without undoing the axle from the frame or spring - there is a "skosh" of play here in the free motion of the spring/shackles.
Where the pix says "Oil Enclosure," you'll be looking in just below the small "e."
All you need is about 1" of clear view - and I think the length of the rear spline on the universal will allow the axle, torque tube, and drive shaft to move rear-ward without everything coming apart and the torque tube dropping to the floor.
OBTW, the pix is from Victor Page's "Model A Ford" book which was printed first early in 1928, and shows the "ring style" universal in cross section.
Joe K
If you do not know which type you have and it is the needle type, ok to grease the needle type same method as the ring type ("more is better")?
It has not been mentioned, but grease is only REQUIRED on the early "ring" type universal joint.
The later "cross & yoke" style popularized by Dana/Spicer are made with sealed needle bearings - which are pre-lubricated. Some of the crosses DO include a grease zerk which is a one-time fill until you see it squirt from the needle seals, but no more - much like any zerk lubricated bearing.
In many modern cars and trucks these universals are fully exposed to the weather and soldier on in their function for a good 100K miles. One wonders how long they would last in an enclosed space such as the universal clamshell?
I usually put only enough grease into the clamshell to "coat" the yokes/cross to prevent rust and allow the clamshell free movement. Also the splines need a dab of grease on assembly as there is the possibility of a sliding fit here.
If you own the earlier "ring" type universal - more is better - up to a point where the universal slings it off. I might give that one a cup or so of grease.
Joe K
I’d sure like to see that Dana Spicer get installed on the yokes of a Model A. It’s well known the riveted original ujoint will not last. The ujoint with the retainer rings last much longer with adequate lubrication. I coat the spherical surfaces of the torque tube, center plate and clamshell halves and the remainder of a grease tube in and around the ujoint with a tube of grease. Depending on how much grease squeezes out of the clamshell, I give the grease fitting on the bottom front piece of the clamshell about 20 pumps every 500 miles when I grease the rest of the chassis.
I have had to put in up to one full tube of John Deere Cornhead Grease. I guess it all depends on how long it has been since the last time it was serviced.
Be careful with the nuts on speedo drive. If they haven’t been loosened in a long time, use a lot of penetrating oil. They can break. Enjoy.
Ditto to the bolts on the speedo drive cover; however, after filling with John Deere Cornhead, the stuff appeared to liquify enough to leak out the clamshell seals. We cleaned it out and reverted back to chassis grease. Perhaps others can explain their experience with the Cornead. It has been OK in the steering gear which isn't under constant turning motion as with the universal.
Hello to each other, I can tell now something about filling quantity with grease from practice:
Here in the forum I have read that so much grease should be pressed in the universal joint until it swells out of the speedometer drive out. I did that about 40 miles ago.
Today I controlled the gear oil with the dipstick, installed 2 days ago. And now find a lot of grease mixed with the gear oil!
Only downside I can think of is the tendency for grease to liquefy by the heat and motion of mechanical action: centrifugal force will put it at the point most likely to find its way past the cork seal. Others have mentioned a tendency to "issue forth."
And yes there would be a small power loss particularly until the grease has been relocated.
But the Torque Tube/Universal worked for Ford in both the Model T and the Model A, and with improvements up to the end of the torque tube era.
Given the supply of Dana-Spicer U-joints that are out there (in another thread I have mentioned some "variability" of supply - at least from D-S) and the problems that Ford got past by adopting the Cross & Yoke design, if you're apart and see you have the ring style, don't use it. Do something better.
If not apart, just wait until you are - for whatever reason.
If it ain't broke, don't fix it.
Joe K
I have never seen a sealed needle type Spicer ujoint in a Model A. If they make such a thing I’d like to see pictures of it secured to the output shaft of the transmission as well the yoke to the driveshaft. Either way you need to keep the clam shell lubricated with grease. There was originally a felt packing on the rear shell halves l, now replaced with cork. Do as Richard in Anaheim recommends. Remove speedometer gear and pump grease in fitting until grease appears.
Post 28 and 29 have answered my concern. I missed or was unaware of this info if in the earlier posts, that the needle type was quickly replaced at the beginning production of A's. Since My truck is a late 30, I have the ring sytle/cross and yoke design.
Thanks for the info.
This is what a replacement universal joint for a Model A looks like. There are no needle bearings. This is a sleeve type bearing.
I just remove one of the bolts.
Back to the grease quantity:
So unhealthy looks the mush! Gearbox"oil"contaminated with the grease from the universal shell.
