Dennis Jarrell
I have been looking at new cranks for my 8BA and I was wondering since I'm buying all new stuff would I be wrong in buying a 4.25 stroker?
Thanks,
Dennis
Thanks,
Dennis
The plan is for a very hot street motor for my 35. 3 5/16 bore by 4.25 stroke. Edlebrock heads, three 97's, either a Isky 404 or the biggest comp. thumper cam.
The reason I wanted the 404 cam is because a good friend of mine has one in his and runs so good and has had no trouble with it. It has been running for many years. The reason I was going to stay at 5/16 was also because of my friends first flattie that was 3 3/8 had worn the cross hatch at the studs in the bores after a just a few miles so we thought the bore was too much.
Not necessarily, but I couldn't resist.
<LI class=sa_wr>Depends on how high you want to get. lol
<LI class=sa_wr>Urban Dictionary: crank
www.urbandictionary.com/define.php?term=crank
Slang, noun. “Crank” is slang for a low purity, crystallized Methamphetamine that is administered in a powder form. Crank, like all other Methamphe...
If you have no sense of humor, I suppose it is not funny.Is this supposed to be funny?
The reason your friend's bores wore at the studs is the block was not honed with a torque plate so the bores were not round.
I have been running flatheads with 3 7/16 bores since 1952 and never had any indications of distorted bores. We ran some of these with 100% nitro. Even ran picric acid and hydrazine in one of them.
