roblesterjr04
I see a lot of threads and posts about proper maintenance with guys checking this joint, or trying to fix this leak, or constantly adjusting the carb to get that perfect mixture.
My question here, is if I just stick to the lube schedule, and keep an eye on my oil, and my engine runs reasonably ok, do I need to worry? Can I just drive it until I have a real problem?
I ask because I've been rebuilding the body of a 1929 Fordor I picked up. The engine ran (and still does) even though it looked like it came out of a lake. I treated it with rust-stop and painted it, and it still runs well. Fresh oil, almost all the gaskets, new water pump, and a fresh timing. She starts and runs well. Haven't checked oil in trans or rear yet, but plan on doing that before I actually drive it more than around the block. I'm gonna re-hab the brakes and then send her off to paint.
the point is, I didn't do a frame off, even though it could use it. I didn't pull and rebuild the engine, even though, by some standards i've seen here, other folks would have. It's my first time with an A, let alone a complete restore.
If it runs well, and its safe and fun to drive, how much work do I really need to put in to it, other than fixing it and making it look nice?
