braol
Well, I'm finally doing the clutch job in my '31 Tudor I promised this summer! Things are going swimmingly: After only about three hours of work I got everything disconnected and am ready to pull the suspension out the back. (Pictures forthcoming...)
Big question though: After I jacked-up the back of the car I went to spin the rear wheels to check for balance or any rear wheel bearing grinding. There is no grinding BUT the rear wheels are anything BUT free-wheeling. Is this normal? I know that the rears are just a regular roller bearing and not a tapered pair of bearings like the front. Perhaps the rear brakes are adjusted too tight....? I will be adjusting brakes after suspension is reinstalled after the clutch job so perhaps I'll find out. I was just shocked that the rear wheels don't just spin 'round and 'round like the fronts do. Maybe some clearance(s) in the rear end/differential are wonky???
