smittykid
Long story short, I moved the third brush quite a ways up on the armature to reduce the output. I also replaced the stock cut out with a NUREX diode cut out. The system is still 6 volt pos. ground. After adjusting the 3rd brush-it reads 2 to 3 amps at idle and about 10 amps at fast idle or about 40 mph. I'm being told that is still to high a charge rate. How far can you move that 3rd brush up? When I turn the lights on at fast idle the amp meter goes down to 0-1 amp. Now what?
