Thanks, just finished, gave them a slight drag on both sides, before, just free wheel...There is only one adjustment on the top using the square shaft spring loaded.
There is a cam located inside the brake drum behind the brake shoe located about the end of the return spring in your photo.
None of the early hydraulic brakes had a lower adjustment, except 39 Ford which had eccentric bolts on the bottom brake shoe attachment. It appears you have 40-48 Ford backing plates.
Not sure if this is homemade juice brakes or what but want to adjust my shoes to grab better, on the back of the front hub there are two spring loaded bolts on l/r top, do I adjust as normal?
but why no adjusters on the bottom?![]()
Question by cajunfirehawk:- why no adjusters on the bottom?
