socalplanedoc
OK, you guys, come clean. Exactly what method should I be using to test the compression on my A? (no jokes)
I've asked a couple of time in threads and sent a couple of PMs but no one is divulging the secret code.
Been trying to get a handle on my engine.. wont idle, runs rich. yada yada. so today I got new plugs and headed out to check the compression...
So the thread is way bigger than my usual tester so I whipped out my handy-dandy universal tapered-rubber-nozzle universal test-anything compression tester..
I jammed it home into the #1 hole and yanked on the started rod.
next thing you know.. Kah-BAMM! you'd thought an M80 went off..
I went over to the yard and retrieved it.. put the face bezel and plastic glass back on.. then this time I got the engine spinning and proceeded to push it in the hole. I cant hold it in! I saw the needle swing past 75 twice and gave up on that one.. the other 3 were the same way.
Now, I've heard people saying things like 50 and 60 were typcial numbers so, what's the deal?
At least they're all the same...
Come'on now, tell me the secret, let me in the club
