I'm working on a friends 63 Galaxie, I need to know the procedure for bypassing the voltage regulator to see if the generator is putting out so I can tell if it has a bad gen. or regulator.
I know on GMs you can ground the field terminal to bypass the regulator but I'm certaain Fords are wired different so I'm sure the procedure is different.
Thanks. Billy
Thanks. Billy
