ajmac
Hi Guys,
I have not posted before on this forum as I normally use HMVF for WW2 vehicles, this however may be the only place to find out the answer!
I've got what I believe to be an original factory fitted 1941 81A cam with the only markings being 5-T on the nose. I also have a cam from an unknown history 59A, again the only markings are 5-T on the nose. I have been told that I can't fit the 59A into the older block as the cam changed when the valve angles were adjusted from 101.5 deg to 100 deg when the 59A was introduced. Is this true? Secondly, how did Ford mark the cams, there MUST have been a part number to differentiate different grinds....or am I being too practical?
I don't hold up much hope on the numbers front as the cam from the 81A is the long nose type to drive the divers helmet distributor and the 59A is the short nose for the 1942-48 crab style distributor and they both have the 5-T stamped on them as mentioned earlier!
Thanks,
Alastair
Thanks,
Alastair
