james hitchcock
I was having lots of fun tinkering with my recently acquired 31 pu (soon to be Huckster) I cleaned up the engine, pulled the head (all looked great inside) replaced all gaskets, new plugs, filled her up with oil. Thought that today I would try to get her started and rigged up a small plastic jug to get her some gas (haven't cleaned out the tank yet) Then I remembered I hadn't put any water in the radiator. I'm filling the radiator when I see water dripping from all around the head. I stopped the water and quickly drained the radiator. I was able to crank down the head bolts a bit more. This may sound stupid but, was I to put on some sorta gasket seal on the new copper gasket. How bad can this be. I pulled a plug out and didn't get any water. As of first thing I didn't get water on the dip stick. I'm hoping I didn't wreck everything I had done previously. Do I now need to pull the head ? Drain all the oil ? What should I do. I'm so disgusted with myself. Suggestions welcome.
James.
James.
