Hot Rod oil
Have you ever heard of Hot Rod Oil.
It came in a rectangular metal gallon can.
The original Hot Rod Oil was a double re-refined oil made
by the Seitz Oil Products in Syracuse, NY.
The third image posted by Pete Hoovie was on the can
I saw at an auction. I couldn't believe it went for $1500.
"Re-refined"
Back in the day that term referred to used oil that was recycled.
The term still applies today.
Bob
Ah, back to chemistry class days...
Refining is basically a fractional distillation process where the raw mix is boiled, then because each component condenses at a different temperature you set your equipment up so you capture each fraction (component) as it cools and condenses. I presume with the equipment in common use there was a fair amount of cross-contamination of the various fractions. So a second distillation would help purify each fraction. Then you mix the purified fractions to your secret recipe (and add urbs and ices) to get your snake... er hot rod oil.
