goshencars
When I flip the lever to start on my Ignition switch on my 40 the switch enclosure gets hot. Almost to hot to touch. Is this normal? I took it apart and it looked OK. Is there a fix? Is there a short? Thanks
Take it apart and clean the contacts. Do not use sandpaper to clean contacts. Also clean the brass threaded terminals on the back of the switch and look at each wire terminal carefully for damage of a loose connection to the wire. Reassemble make sure all is clean and snug.
