Hot idle adjustment screw
Jim Yergin
I have a Holley 4000 carburetor in my '56 Thunderbird. I cannot see what the hot idle speed adjustment screw pushes against to raise and lower idle speed. Here is a picture of my screw. Am I missing a part or do I just not understand how it works?
Thanks.
Jim Yergin
The hot idle speed adjusting screw (with the spring on it) is supposed to contact that round pin directly in front of it. Either the dashpot screw on the throttle lever is adjusted too far out, or the fast idle cam on the other side of carb isn't dropping (choke not all the way opened ?). Or the return spring on the throttle linkage isn't working.
Sal
Took a picture of mine - yes, rests on the rod. Looks like you linkage need adjusting or the screw has to be adjusted in some more
