horsepower CHECK
normren
I'm helping a friend with a engine we are trying to figure out they get it tried to find somewhere to look but not much help
Horsepower calculator
Engine dyno
Any one has a good set up were you can punch all the numbers in ?
You looking to predict hp on a build, or figure out what you’ve got in hand? Lots of variables in modified engines.
There are several definitions for horse power. One is calculated using the bore, stroke, mean effective pressure, and clearance volume then multiply by the number of cylinders using the PLANK formula for indicated horsepower. Dynamometer tests take all the other not so calculable factors such as camshaft lift/duration, type of fuel system, and turbo/supercharging effects. Brake horse power is about drive train loss so there are more than a few ways to come up with the ratings. The British had the most interesting way to rate horsepower for taxing purposes.
Manufacturers had horsepower ratings for the products they produced but it largely depends on the make, model, and year of manufacture with the type of engine used. Is this for a Y-block Ford engine?
