Horn
C4engr
Can I wire the HORN per the Model A wiring diagram and not use the Tail and Headlight portion of the Lighting Switch..??
Thanks for the confirmation.... I will try doing that in the morning...
Have a great A Day....
Rog
Run the power wire to the cutout, then run the other horn terminal to the center contact on the switch plate. You don't even have to buy the lighting harness.
