you will need a continuity tester, . Most modern electrical test consoles have one that emits a sound when you have continuity. On older ones you can use the ohmmeter as one. I suspect the spring loaded horn contact in the switch plate is bad. To test the rod, clip one probe to the end contact and another to ground and press the button. It should sound (or indicate contact if the needle swings on an ohmmeter). If not, the rod or button is defective. Another thing to check is that the rod has the bronze bushing at the top, which helps make contact to ground for the rod. If it does show continuity, the problem is elsewhere. Next, clip a probe to the spring loaded, center horn contact on the switch plate, and another to the ground wire at the horn. It should show continuity. If not, the problem is somewhere in that line, most likely at a crimped fitting like the clip or the spring loaded contact. If that lead shows good continuity, check that the spring loaded contact is actually contacting the end of the rod.
