Horn wiring question
oldbike99
Does it matter which horn wire is which? My horn has been altered to have two red wires! Thank you in advance.
An original horn has NO wires. Only internal (under the cover) spring bronze clips for the bullet connectors on the vehicle wiring harness. On original horns one lead is always "hot", the other is ground only when the horn button is pushed. The motor itself has a wound field so it is insensitive to polarity. Switching the wires does not matter.
