doug.nichols
I just finished installing a new rebuilt engine and a negative ground cut off switch. The car drives fine. When I reattached the light/horn wires to the alternator and closed the cut off switch, the horn started to toot and would not stop until I opened the cut off switch. Does anyone have an idea of what might be causing this? I have not done any work to the light switch, which is new a few months ago, and the horn is a new rebuilt 12v unit that worked fine before my engine change and switch installation. Is there a way to hook the horn up backwards? Any other ideas?
Thanks
Thanks
