Horn stops working
miff
My horn will turn with no pressure on the diagram. But when I start to adjust it for the sound. ( a click at a time) when it starts to put pressure ( very little )on the diagram the arbor stops turning . With no pressure it spins fast and free. Any ideas , (it's an Ames horn) Miff
I've cleaned commutators with emery cloth while the armature spins. Between that and a few drops of oil on the felts, the horn blows great.
I want to thank you all for your suggestion on my horn. I want to thank Mike v Florida fro sending to horn basics by Payl R Modlin. Followed his problems and solutions . The horn works great . Miff
That's good it's working. Another maintenance area is the bullet connections and clips not clean enough. I also found a brush not in position correctly, yet still partially working.
