What do you mean by 'fruits'? The problem you'll experience with a bent horn rod is that every time you turn the steering wheel, the lights will go either on or off on account of the bend in the rod hanging up inside of the steering shaft.
You get the lollipop Brian. I was not sure as I have not had the problem. I removed the rod because I was installing a Saginaw 525 for better steering. (Ease) I noticed that the rod was not absolutely perfect and had some wear marks where the steering lock bracket is attached to the shaft. Evidently not enough to turn the light switch. Thanx
