Horn Rod Repair
Charles Reese
Any ‘secrets’ for bending the 4 tangs (or other landmines!) that hold the horn button retainer ring to the face plate of the horn/light switch? Need to remove in order to have button, retainer ring, and faceplate replated.
Charles, the ring is brass and the tabs can break off easially. Remove it carefully. If you break it, others are around and it should be easy to replace. Good luck.
