Complete with the wire contacts, insulators, horn button and escutcheon. The length is measured on the tube part from the top of the tube where the tube goes into the head, down to the keeper groove.
NOTE: A-3616-B is used on the 7-Tooth Columns and A-3616-C is used on the 2-Tooth columns. U.S.A.
Below are shaft measurements , not light switch rod measurement. If your original light rod is missing, measure the steering shaft with a piece of string or wire.
A-3616-B = 44-1/2"
A-3616-C = 43"
A-3616-F = 44-1/2"
A-3616-G = 43"
A-3616-H = 44"
