jfcrash
Another loose end before I can get this restoration on the road !!
Ref 35 Horn Rod…
I have all new wiring and last fall the lights and horns worked… however, when I would turn the steering wheel, the light disk would also rotate with the steering wheel turning the lights on and off.. Suggestion was to add a horn rod sleeve/shim which is available from Mac’s.
Just put it in and solved the problem of the light disk dragging on the steering wheel….however now the horns don’t work..
By removing the light switch bulb at the end of the steering I get continuity from the tip of the horn rod to chassis ground when the horn button depressed… so is seems this shim has raised the horn rod enough so it does not make contact with the center of the light switch bulb.
Can anyone offer a suggestion or two other than removing the shim ?
Thanks Jim
Ref 35 Horn Rod…
Thanks Jim
