I just adjusted my 2-tooth steering box and replaced the wire in the horn rod. The rod w/ button was tested for proper function both on the bench and in the column (before the spring and spider were installed). There was continuity, i.e., grounding only when the button is pushed. The problem is that now, after installing the spring and spider, the continuity is continuous, such that the horn would always be sounding.
I pulled the horn rod and repeated the initial testing, which was OK, but once the spring and spider are back in, the same problem occurs! What should I be looking for? Thanks much!
